- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
SONY CT780 - Replacement Sub-woofer
Hi, I've recently been given a Sony HTCT780 soundbar but it didn't come with the Sub-woofer , it packed in Can anyone advise me on a replacement ? Can i buy any Sony wireless sub or does it have to match the soundbar model ? Can i buy a none Sony replacement ? Any advice appreciated .. Cheers Angus
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi there
The subwoofer model number required is: SA-WCT780 problem is that you csnnot purchase this subwoofer or any other compatible subwoofer on its own. They are packaged as a whole unit/set.
You should be able to use the soundbar in a 2.0 setup.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Thanks for the info ..Not good news but I'll keep my eye on Ebay ...
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Would a sub from another model work , CT180 for example ?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I have absolutely no idea im afraid. You could contact Sony Support - but i would probably guess that they give the stock answer of that only the right subwoofer will work....
The only advice i can really give is to compair the two devices specification in the support manuals.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Keep in mind in any case that inside the subwoofer of Sony soundbars is the main controller of the soundbar itself.... so it's like changing the whole system
