Hi, got a problem with the mirroring function on my bdv-n5200w system. My laptop recognizes the system and it pops up a square saying "please wait" and then nothing happens and then it times out and i need to start over and make it visible again. Any suggestions?
is it possible that my asus e403s doesn't support the system in somehow?
Hi there
Ive always had issues with miracast connectivity via laptops - its hit and miss. Google is your friend on this one to be honest. First you need to know if your network card is miracast certified or not. See: http://www.wi-fi.org/discover-wi-fi/wi-fi-certified-miracast
Hi again!
I can't really find any information on my qualcomm atheros ar946x wireless adapter at wi-fi alliance. But just that i can find the system under devices->project->add wireless display is pretty weird if my network card is'nt miracast certified.
Thanks again!
Hi there
The products that are Miracast certified are normally intel products. I had a search for your network card and have no results - therefore one has to conclude that it is not compatible with Miracast.
As an example of a common Intel NIC, see pic below.
But then again, ive just found this page:
Hi again!
So maybe a driver update can solve the problem? The one he mentioned? http://www.driverscape.com/download/qualcomm-atheros-ar946x-wireless-network-adapter
Seems like I already have the latest version 10.0.0.321 driver
Just read a report of system data via dxdiag and it says miracast is supported. Hmm...Something morei can try?
