XZ1 compact Freezes or restarts / reboot itself
Charlie030
Visitor
My XZ1 Compact has been freezing or restarting / reboot itself since a few days, if I use whatsapp or make a call by re-dial, not always but very often. Yesterday during using whatsapp, whatsapp freezes and i tried a restard it took nearly 10 minutes restarting phone.
Today i started a call via re-dialing from call history, my phone restarts from alone.
Does anyone has the same problems ?
75 REPLIES 75
matzzz31
Visitor
Get the some Problem...
Crashes / Freeze almost Every Day...  Sry Sony but this is lame!
AlphaUrd
Visitor
Ok, so I posted before and tried to do something about it. I used Xperia companion to do a software repair (make sure u backup your data since everything is deleted, like factory resets) followed the instructions for the repair and then tried my phone. My freeze issue happened due to voice input and almost can force trigger the phone's reboot by now. After software repair I tried to spam all sorts of voice commands on gogle assistant and google search and calls and WhatsApp Voice notes, no freeze and no reboot occurred. The issue came back when I did a software update, so today I'll do another software repair and if it went back to the version before I'll avoid the software update and post a reply here again to let you know.
Tags (2)
AlphaUrd
Visitor
So to continue my efforts, I tried another solution I found on another forum for an older Xperia phone. Strangely, turning off auto-updates on the appstore fixed the freezing issue, I tried it and also tried turning off the "say ok Google at any time". Even if u don't use it, having it open messes up the applications voice-input features somehow. Here are the steps on how to do it:
-- Go to "Settings"
-- Scroll down and Choose "Google: services and preferences "
--  Scroll down until you find "Search" click it then look for the "voice" option and click it.
--Here you'll find the "Ok google detection"  option, click on it then you can uncheck the "Say ok google at any time".
Hope these help others since it seems these are what messes up all other applications, a Google issue rather than Sony hardware issue which made me feelso much better since I'm a faithful Sony fan.
Tags (2)
Keyakizaka46
Visitor
Thanks, this works for me! The issue has been largely resolved by now, I will keep an eye on it and see how it goes.
Jean63120
Visitor
I disabled Google application there are few days and I haven't reboot issue anymore.
Disabling Google means disabling "Ok google detection" too, so I think you found the good fixes.
I try disabling only "Ok google dectetion".
Supercharged_Sp
Visitor
Agreed.. Slightly_smiling_Face
Timbo84
Visitor
Interesting comment on WiFi above. My phone almost always crashes when I get in my car leaving my work WiFi network and connecting to my car via Bluetooth (these tend to happen at the same time). WhatsApp video calls have also caused it to fall over.
Have switched off the Google voice setting as suggested above.
COME ON SONY..
HikariKobushi
Visitor
I have experienced few reboots on my XZ1c as well. One while I was making pictures, another while making video chat through FB Messenger and another when picking up a phone call. I have erased the data and setup my phone as new again and reboots stopped so far.
friendofsony
Visitor
Did a software repair in Xperia Companion in hope of fixing the reboot problem but when I tried to restore from my backup it just stopped at about 30 %. And even with a fresh start it just rebooted now while at work connected to WiFi. What a rubbish experience...
charno
Visitor
I've had my XZ1 for a week, upgraded from the Z5 and now starting to wonder if I did the right thing.
I noticed that the SMS messaging app is not the Sony version (which I find was much better and can be customized better, backgrounds etc) I installed a version of that but had all kinds of issues with the phone and continual pop ups that the app had stopped working. Had to uninstall that and go with the inferior Google app.
Ive had reboot issues from day one as well as apps hanging and have tried repairing the software but to no avail.
Main culprit seems to be Google assistant, when I go to use it the app will quite often freeze and then the phone restarts.
Other issues I've noticed are GPS lag or hang, apps failing to start and have to be force closed and when making a phone call it is taking ages to start ringing.
Sony.... What's going on?
