XZ1 compact Freezes or restarts / reboot itself
Charlie030
Visitor
My XZ1 Compact has been freezing or restarting / reboot itself since a few days, if I use whatsapp or make a call by re-dial, not always but very often. Yesterday during using whatsapp, whatsapp freezes and i tried a restard it took nearly 10 minutes restarting phone.
Today i started a call via re-dialing from call history, my phone restarts from alone.
Does anyone has the same problems ?
75 REPLIES 75
friendofsony
Visitor
Actually I haven't had a restart in a very long time, and even Smart Lock suddenly started working without the workaround. I'm starting to think that Google has fixed this through their Google app on Play Store.
Now downloading 47.1.A.12.34 OTA.
Mrlando
New
I've had the problem since I had the phone too (November 2017) . Did a software repair a month ago which made no difference.  Did the firmware update to 47.1.A.12.34 a couple of nights ago.... Still randomly restarting... Even if I've not been using the phone for a bit (I only noticed when I tried to use my phone it said "Pin required after restarts"
djmien
Visitor
Hi there I found really weird and annoying bug, which is caused by downloading data by 3rd party app Vainglory game, when it downloads it's data (not on google playstore but in-app) and I want to minimise app duringd downloading and do something else the phone becomes literally unusable, pressing home or multitasking takes 10 seconds if you have luck, phone is laggy like it has 1Mhz core processor, I think it's something with the software which cant handle using memory and doing anything else at the time, could you try it on your xz1 and tell me if you have the same problem?
ChiliPepper11
Visitor
My XZ1 (not compact) has been randomly restarting with no common pattern or something. It just restarts, sometimes 4-5 timesttin a row and sometimes it just restarts one time and it is okay and I heard it is a problem about OreoOin general it even happens in Google's pixels too
Dajazzman
Visitor
Exact same problem and seems to be getting worse. It has made me never want to have a Sony phone again. Which is a shame as I have been a Sony phone fan for the last 7 years. Tried resetting, rebooting, uninstalling apps but the problem persists. Sadly eight months to go before an upgrade. Going to be a long eight months.
mrul
Visitor
I had the same problem. I just bought the phone, installed all the updates OTA, then it started to reboot randomly. After 2 days, I had to flash a wifi qr-code and then it froze and went in bootloop.
The firmware version is 47.1.A.12.145.
I have the chance to halt it, but I had to go very fast at the end of the boot.
I finally sent it back to the vendor. I was a big fan a Sony smartphones, but I'm very dissapointed by the lack of support...
