I have a sony kpcg-k215b and have just got a wirless router do I also have to have a wirless adaptor or is there already one in the computer.
Francis
I dont think there is on the K21 Series, if there is there will be a switch on the front of the laptop which reads 'wireless lan'
If there isnt, you need a PCMCIA Wifi Card, they are about £50
hi
i am using wireless connection with my gr215sp. i am using a belkin all in one solution [router and modem all in one moder 7630 and i am also using belkin pcmcia card model 7010. i use this for broadband it works a treat. i has also made my laptop proform faster without any probs.try to buy belkin as they give a life time cover.if any belkin products have a sudden death u just have to contact them for free replacement.
You pay more for Belkin, but it's always worth it.
They're really good at support too.
