Howdy,
What is the best hard ware/method of connecting your PV to your stereo?
C.
Simple, a 3.5mm minijack to RCA stereo cable.
It would have been nice to have optical connections like all MD but for some reason Sony decided not to.
Is there a sony version of an iTrip?
Unfortunately there are no accessories for the VP at the mo, and assuming the VP doesn't take the world by storm I doubt we'll be seeing any. You can buy a non-official transmitter that will work with the VP, I've seen a couple of ppl on here who have said they bought one but i wouldnt know where to get one from. I use a cheap cable which splits into the stereo input ports on my hi-fi and it sounds great, but you can spend a fortune on cables should you wish.
