VGN-TX1XP
fouadm
Początkujący
VGN-TX1XP
hi all, in my new TX there is My Club Vaio progrem which was display ok till i chosse automatic sync than it's only displays Black screen With my club vaio logo in the middle, I cant go to it's seeting again to restore ........any ideas!!
thank you in advance for your help.
Regards all.
7 ODPOW. 7
profile.country.GB.title
Thalamus.
VIP
Regards all.
There is currently a problem with Sony's server so a CV member has been informed by Vaio-link stating, something like, they are aware of the problem and it should be solved soon.
So you can relax it's nothing wrong with your Vaio
Thalamus.
VIP
Here is a link to the other thread if you are interested.:smileyhappy:
fouadm
Początkujący
thanks for ur replay, i just saw other C.V.Members posts and all we can do is wait for sony , but as i saw ...some members solved but i can't understand how?? as nothing appers u can click or return the x setting !! any idea??
again thanks for your help,
regards
Thalamus.
VIP
You're welcome fouadm,
I don't think they have solved the problem as the problem, it appears, lies with Sony's Server. I guess some members may have just turned off the sycronisation option. :slight_smile:
fouadm
Początkujący
ok, first sorry to disturb u again but how may have just turned off the sycronisation option??
thx
Thalamus.
VIP
I don't know who has turned off the sycronisation option, I for one have not changed any settings in My Club Vaio program. To be honest I don't really use it.
I either go to Vaio-Link or to Club Vaio. :slight_smile:
Sepheron
Początkujący
Regards all.
Easy! to restore it as it was before, just disconect from every network you're on and louch My Club Vaio. i'll say that you don't have an internet conection and it can't "sync", then u enter the offline mode and can access the "settings" and turn off auto sync! 😃
Regards,
Sepheron
