Hi
I like to install windows xp prof in my language (right now windows xp home).
How can i install al the softves, but i have no recovery cd. (I hav particion)
Any id?
Thanks Krisz from Hungary
install the windows that came with the computer ( xp home ) and then insert the xp prof. cd and upgarde to xp professional.
I dont have the xphome (I alredy installed xp prof 😞 ) Right now i cant install any softver. If you tel me how i can reinstal xphome then i will try it
did u remove the recovery partition?
if u didn't,
restart ur computer and press F10 to reinstall windows xp home edition.
the recovery partition is working.
version error or something so i can't recover.
Is it posible to get just the softvers somehow?
Thank's
