Hi. I've a problem when connecting my FE11M to my hifi-system. I get a kind of unwanted signal. I made a little sample which can be found here: click .
This noise appears only if the notebook is connected to the power supply.
While using the battery power there is no such noise. The noise also is not there if i use headphones (or I simple do not hear it) or if i connect it to my active computer speakers.
Anybody here with the same problem who can help me. Or someone else who have a solution for this problem?
Thanks and greets from Germany.
Ok, i was able to "solve" the problem. I found a noise filter at home which filters out the disturbing noise.
