- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Hi - Does anyone know if the W6 Series TVs are 100hz or 200 hz TVs?
Also it seems that there is not a motionflow speed setting, like high, medium, low. From what I can see they seem to be linked to the scenes.
Is anyone able to advise if this is true and if so is sport technicaly the fastest motion flow setting? If so I would use sport and then tweak the other settings like contrast etc and use for all viewing.
This TV is an upgrade from a 50hz so I would like to be able to use the settings if they are available. If anyone can advise that wolud be great. Cheers
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi there
The W6 range uses what Sony calls "Motionflow XR 200hz. This is actually a 100hz TV, that does extra processing to "feel like" 200hz.
Hope that helps
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I don't suppose anyone knows if its running at 100 for everything other than game and movie mode or if it varies with each scene is sport the fastest/smoothest setting?
