Netflix Update Issue - KDL-42W829B
SOLVED
munkian
Member
Hi Guys
I got a new KDL-42W829B yesterday, set it all up fine, everything working.
Today Netflix app isn't working - TV says update required, I click to get update then says no new version avaliable
its then stuck in this loop
Other online apps are fine, firmware is up to date (downloaded to USB) Tv said its same version
Reset to factory settings, still no joy
Does anyone have any ideas ?
Thanks
54 REPLIES 54
boomball
Explorer
Hi Quinnicus Not having a go at you at all - and I'm not really that annoyed - as I said it works fine on the Blueray attached to the TV - so I'm able to watch anyway - but it's clearly a TV issue, and I'm pretty sure the last update did fix the Netflix issues with the Sony TV's - so the math is pretty clear But I see the boffins are workin' away - so it should be fixed soon
classic9
New
I am facing the same problem on my W955BBU
nstevens68
Explorer
Same problem on my KDL-42W706B come on sony sort this out.. I am having to go back to my apple TV and i hope that gives you a problem in terms of the image you want to promote
profile.country.DK.title
Reerso
Explorer
Here is a response from netflix: Netflix Sauna
We have been getting reports of issues this Sony TVs and so our engineers have been made aware that some customers using Sony televisions are being prompted to perform an update when launching the Netflix app, but then it fails to load. Our engineering are working hard at resolving this issue right now as well
vblease
Explorer
FYI - It's now working for us. There was a message prompting to reactivate Netflix, all worked as normal after that.
Reerso
Explorer
It works here too 🙂
andrekrit
Explorer
Working again :smileyhappy:. Did not have to reactivate or anything.
teefy-uk
Explorer
Likewise - working here, no reactivation. Yay! Thanks Sony/Netflix :slight_smile:
Wuuhuu! Works for me too!
Cainer
Explorer
Well done Sony and Netflix for getting onto this and fixing it quickly.
Thanks.
