Hi Guys
I got a new KDL-42W829B yesterday, set it all up fine, everything working.
Today Netflix app isn't working - TV says update required, I click to get update then says no new version avaliable
its then stuck in this loop
Other online apps are fine, firmware is up to date (downloaded to USB) Tv said its same version
Reset to factory settings, still no joy
Does anyone have any ideas ?
Thanks
Hi boomball
I appreciate that your annoyed with the Netflix problems. Please bear in mind that im not a Sony employee and are in fact one of you guys - what im getting at is "dont shoot the messanger"
Netflix, just like BBC iPlayer, has many different software versions - as each device can be slighly different. This could explain why it works on a Bluray player or PS3, but not some 2014 TVs.
In regards to the resolution of Netflix's previous issue, it was actually pure coincidence that it was resolved on the same day as the FW update. This is why there was a time delay between the update and Netflix working. So it was assumed that the FW update fixed the problem - I dont know exactly what fixed the problem by the way.
@teefy-uk - The way I see it, it would be under Contract Law
You buy a Sony TV with Netflix, your Contract is therefore with Sony. So if Netflix doesnt work, you compain to Sony. Sony therefore has a Contract with Netflix, who will complain to Netflix. Sony and Netflix will then work together to resolve the issue as Netflix would probably need expertise from Sony as well.
PS : Just guessing and calling it how I see it - and excluding other variables such as ISP issues
I have just been chatting with a netflix employee, they are also aware of the problem and he informed me that they have located the problem problem and are working on fixing it:
Netflix Christopher
Ah yes that is correct. I am currently chatting with my engineers, they have receive reports that members are getting prompt to update the app but it is not going through. No worries though you are doing everything right on your end, and they want to thank you for reporting that you are experiencing this issue.
Netflix Christopher
They have informed me that they have located a fix to it and it is only a matter of time and it should be back up and running.
Just joined to say, NetFlix not working, me too
(Making sure the impact is logged)
Same issue for KDL-40W605B
me too
