x
Aerial blocking wifi
We have connected a tv in our bedroom with an aerial cable in our bedroom to enable us to watch live television.
As soon as we connected it, we were unable to connect to WiFi.
A similar thing happened when we did this with another tv downstairs. As soon as the cable went in, nothing!
I have tried turning off and on, I have tried a factory reset, it will not connect to the internet anymore as long as that cable is in the back, so I can’t do both in one tv which is really frustrating!
Help....
1 REPLY 1
profile.country.GB.title
Mick_D
Moderator
Hi Laura, welcome to the Community.
Can you describe the tv model(s) and any other components connected to the TV? It would help others in the Community find a solution for you with more info.
Thanks
Mick
