I've been bought a PSLX300USB turntable for my birthday recently but i'm unsure what the best way of connecting it to my home cinema is. There is no audio in on the dvd player.
Hi there
I think you will need a RCA Female to 3.5mm male adaptor. Available on Amazon : HERE
The DAV System has a 3.5mm jack on the front.
To be honest, I have no idea if this will work, however this is the only way that I can see and for £1.60, you wont loose much.
Hi there
