Sony Docking station rdp-x200ip remote control MENU function does not work. It does not move up/down to select albums etc and the ENTER does not work, any suggestion or help please. (All the other remote functions work OK)
Hi
I would like buy sony docking system remote control RDPx-200ip because its missing me
Thank You. Aniko
Hi there
The remote control is available from a number of sites - unfortunately you are not going to like the price!
http://www.4ourhouse.co.uk/rmtcx200ip-remote-control/product.pl?pid=3480595
