Hi there
You might have missed this in the manual, as its on a different page:
These are the parameters:
Hopefully that explains it a little more.
Thanks for the reply.
Yeah, I have it set to Auto Off 30M, but it doesn't auto turn off at all. It's been on for as long as 7 hours without turning off.
My only other thoughs are a wiring problem.
It could also be that it wont turn off until both the ignition is off and the car door is open.
To be honest, Id get someone to have a look at it and check its all correctly wired up.
