x
The UI has stopped working
Ganesan11
Visitor
This message comes every now and then and removes all wallpapers and widgets. It is certainly a disturbing factor while using the phone. Please help to avoid the message.
8 REPLIES 8
Mr1989
Visitor
I also facing same problem
Emil
Enthusiast
Hi @Ganesan1 and @Mr1989!
I'm sorry to hear that you are both experiencing this. Slightly_frowning_Face
 I recommend that you reset your home screen app. Note that this will completely reset your home screen. I recommend that you take a screenshot of how it looks if you want to re-create it after. To reset your home screen go to: Settings > Apps > Tap ... > Show system > Xperia Home > Storage  > Clear data > Ok. Then restart your device.
If you are still experiencing the same behavior I would recommend that you reboot your device to safe mode to see if this behavior is caused by one of you downloaded apps as these are temporarily disabled in this mode.
Keep me posted how it goes! Slightly_smiling_Face
Mr1989
Visitor
Again same issue I am facing
Emil
Enthusiast
@Mr1989, there was no change when your device was in safe mode?
If so I recommend that you perform a software repair using Xperia Companion. Note that this will completely reset your device if there is anything you want to save you have to create a backup using Xperia Companion prior to repairing your device.
koko2309
Visitor
hi, this message appeared for me more time till  i can't open my phone permanently
what can i do ?
Emil
Enthusiast
@koko2309, I'm sorry to hear this. Slightly_frowning_Face
Have you had a chance to try any of the troubleshooting suggested in this thread? If not I would recommend that you try that and let me know if there is any change! Slightly_smiling_Face
koko2309
Visitor
now i can't open my phone and try to setup new software for it ...it success and when i try to open the phone it open till word "SONY" then close again, but when i connect it to the charger it read power only and the red lamp above appear but not recharge the phone, what can i do please ? it may be battery?
LyzaMarie06
Visitor
Same here, im trying to fix now my sony xperia xz...it just keep turning on and off after xperia. i already reset the phone.
