This message comes every now and then and removes all wallpapers and widgets. It is certainly a disturbing factor while using the phone. Please help to avoid the message.
@Ganesan1 wrote:This message comes every now and then and removes all wallpapers and widgets. It is certainly a disturbing factor while using the phone. Please help to avoid the message.
I also facing same problem
I'm sorry to hear that you are both experiencing this.
I recommend that you reset your home screen app. Note that this will completely reset your home screen. I recommend that you take a screenshot of how it looks if you want to re-create it after. To reset your home screen go to: Settings > Apps > Tap ... > Show system > Xperia Home > Storage > Clear data > Ok. Then restart your device.
If you are still experiencing the same behavior I would recommend that you reboot your device to safe mode to see if this behavior is caused by one of you downloaded apps as these are temporarily disabled in this mode.
Keep me posted how it goes!
Again same issue I am facing
@Mr1989, there was no change when your device was in safe mode?
If so I recommend that you perform a software repair using Xperia Companion. Note that this will completely reset your device if there is anything you want to save you have to create a backup using Xperia Companion prior to repairing your device.
hi, this message appeared for me more time till i can't open my phone permanently
what can i do ?
@koko2309, I'm sorry to hear this.
Have you had a chance to try any of the troubleshooting suggested in this thread? If not I would recommend that you try that and let me know if there is any change!
now i can't open my phone and try to setup new software for it ...it success and when i try to open the phone it open till word "SONY" then close again, but when i connect it to the charger it read power only and the red lamp above appear but not recharge the phone, what can i do please ? it may be battery?
Same here, im trying to fix now my sony xperia xz...it just keep turning on and off after xperia. i already reset the phone.
