Hi, when bluetooth is turned on blocking wifi connection to 5Ghz band and connecting only to 2.4Ghz which is slower as 5Ghz band. I resetted network settings, modem was restarted, smartphone was repaired, but problem still persist. Any how to fix that?
In pas was the same problem, but after repair was fixed. Right now was did several repairs problem isn't gone.
Any solution?
Thanks in advance for help
