TV KD 43xg8096
Simple question
Can anyone show me where the aerial socket is on this TV as I cannot make sense od diagram
Many thanks
Kegweg
The terrestrial aerial socket is on the left hand side of the TV,
From the top you will see where you can plug in USB devices.
Below that there are two HDMI inputs.
Below the HDMI inputs are the inputs
for a terrestrial aerial, and at the bottom of that the satellite input.
To recap, look at the input section at the left hand side of the TV
the TV aerial input is second from the bottom.
See the red outlined box in the screenshot below.
Please refer to my reply to your other post yesterday:
https://community.sony.de/t5/android-tv/aerial/m-p/3703631#M47002
No need to create a new post.
Great
I hadn't thoughtof looking at side
Many thanks
