WHEN TV SWITCHED ON THE hdmi NOTIFICATION BAR AT THE TOP OF THE SCREEN APPEARS AND WILL NOT GO AWAY. HOW CAN I REMOVE IT.
ALSO WHEN I SWITCH ON IT AUTOMATICALLY GOES TO hdmi 1 AND i HAVE TO SCROLL THROUGH ALL hdmi OPTIONS TO OPEN WITH hdmi3. WHY DOES THIS HAPPENN , JUST STARTED DOING IT ?
THANKS
TERRY
HI TERRY,
WHICH TV MODEL?
USUALLY YOU CAN TURN OF THE INFO BAR IN THE CHANNEL SETTINGS MENU.
CHEERS
PETER
Hi Betreff
Thanks for reply model is Bravia KD-49XF90xx.
I cannot find the Channel settings menu anywhere ?
Any help gratefully received.
Terry
Sorry Model number is KD-49XF9005
Hi.
Settings - Channel set up - Info banner - Off. This should do it.
Win_88
