good evening to all
I would like to ask a question regarding the android version which is on my TV at the moment I have android 7 but some applications and services it does not support and it tells me that I must have android version 8 and later does anyone know if this particular TV will get android 8 or if there is a file that i can install myself on the TV
thank you
Good afternoon,
Most likely there will be no update to Android 8 for this TV.
