I could give it a try, even the card is empty....
I see That know after i took it out and plugged in again, i can tap the button 'link sd ', which before wasn't even possible to tap on it, however hé does still not indicatie any more extra gb from the card....
But ill try reformat the card and see what its says...
Thnx... .
Whoehoew.... Thnx... You're the hero of the Day... It worked by make the card empty (strange because it was already empty), but Who cares, it works now!!!
Thnx for your help!!
