How can I get downgrade?
Funktioniert... I bought this phone Z3compact 1 month ago and the upgrade did this product ..
Photo and battery are worst... I did test before the upgrade and the picture were very good and now very bad... And battery life is shorter...
Mind the language and the forum guidelines, keep in mind that this is a user based forum, which means, we, users, are trying to help each other, if you want Sony's support then this is how >>> Local support
My suggestion is to reinstall the latest update with PCC and then report back, in 2 days
Bridge (for Mac)
Alternatives on How to backup Xperias
One suggestion before you repair the phone, so you can compare battery life
charge the phone 100% use it as you normally would then once the battery reaches 10%
settings > power management > battery > take screenshots of:
1. the list
2. tap on the graph and take a screenshot
3. back > tap on the top 4 items on the list > take a screenshot of each
post them all here or upload the screenshots to box or dropbox or google drive or etc and post the link
Then, after you repair the phone and update all the apps > restart the phone > charge it 100% > and repeat the same suggestion as above
You have been warned about your posting behavior, you have repeatedly violated the forum guidelines. Your posts have been removed because of that.
