Partilhe a sua experiência!
My NFC suddenly stopped working after I tried to scan my bank card inside RFID protection sleeve.
I tried to restart my phone, used factory reset option, and even perform repair using Xperia Companion software, but nothing seems to help.
In secret testing menu I have this for NFC diagnostic, but I have seen that many people have those same reading and their NFC feature works normally.
I can turn it on inside settings menu, but nothing happens when I touch other NFC phone or any other NFC device, tag etc.
I'm sorry t hear that, what happen when you go to
settings > support > Xperia test > NFC > next > test it
It says: "Hold an NFC object close against your device's NFC reader."
When I do that with my bank card or my Sony SWR10 Smartband, nothing happens.
I was usually getting notification sound and vibration when I put these objects on back of my phone, but now it is not responding at all.
are you willing to repair the phone once more with Xperia Companion > once you do so do NOT restore nor install any apps > test it once more and report back
I did it, and it still won't work.
I even tried to boot my phone into safe mode and it is not helping.
Now, I'm getting really desperate, because I'm using this phone for four and a half years, a I was using NFC for contactless payments (Tap & pay).
I don't know what else can I try to fix this annoying problem.
Just wondering, does your phone has a protective case?
I think you've done everything on your part, you might want to contact your Local Support team to get it inspected.
It does have protective cover, but I take my phone out and it is completelly "naked" when I try to use NFC.
I sent e-mail to a Sony support here in Bosnia and Herzegovina, and I hope that they will help me to solve this problem.
Try another bank card. For example my visa card stoped work with NFC terminals after year of using.
I tried a lot of different NFC devices, but my Xperia Z5 won't react to any of them.
It stopped working after I tried to read my bank card inside this RFID protection sleeve:
Now I don't know how to fix it.
