In this case,there might be a problem with your APN settings. See this topic:
/t5/Xperia-Z1-Z1s/Sony-Xperia-Z1-push-notifications-problems/m-p/522571#M13765
Do you have stamina mode enabled?
Does this occur for mobile data only or both wifi and mobile data?
Strange.Can you try if the same occurs in safe mode with hangouts?
/t5/FAQ/How-to-boot-your-phone-into-safe-mode/m-p/348008#U348008
