Hi there,
what does the entry -2010 mean? Someone have an idea to remove it?
No, i'm afraid i don't know what that is but it doesn't look like it has used any data.
Looking at code.google.com i see it's reported as an issue there: https://code.google.com/p/android/issues/detail?id=79743
What do you see when you tap it?
I have seen that before but I do not know exactly what it could be. I am guessing that it might be related to some usage statistics from Sony or Google or some other system app. Perhaps @Rickard knows more.
