- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Phone is closing/opening apps on its own
Hi
As said, My phone is opening/closing apps and swiping the screen on its own..
It can open apps, close apps, swipe/change sites all on its own.
And when it is in this state i cant even turn off the phone pressing the on/off button.
When it is in this state i cant controll the phone at all, i just have to wait until it stops wich usually takes a few minutes.
Do you think this is caused by an app or is the phone malfunctioning ?
I am using the app ''Master Cleaner'' do speed up the phone and it allso searches the apps for virus. No virus found.
Thanks in advance !
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Yes i do
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
It might be responsible.Could you remove it?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Ok ill give it a try, but the reason i put a screen protector on it is because the screen gets so easily smudged and scratched =P
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I know,but sometimes it might affect the touchscreen and you will see some strange things.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Thanks, it seems to be working now. I removed the screenprotector.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I am glad.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I am currently having this same issue on my mobile phone.
Its opening and closing apps, swiping side ways, making things larger and smaller and changing my settings.
I do not have 'task killer' or 'master cleaner' and a screen protector on my mobile.
I have owned this phone for nearly 2 years.
I have noticed that the screen will stop doing this when i push down and hold my finger in the middle of the screen which allows me to use it by using another finger.
Please help me to fix this, I love this phone and am not keen to be replacing it with another.
Thanks
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I think the problems is the screen. Either the screen is simply broken or moisture has gotten into the phone and reacts on the screen. I had my phone replaced.
Have you had your phone in water recently? Or perhaps you had it repaired? Because after they repair the phone it usually isn't waterproof anymore, sadly.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I have done factory reset too , but nothing wokring
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I also have this problem on a new phone, its 3 months old. No screen protector or anti virus. It started a few days ago with a dead patch on the touch screen when using Chrome. Now today its like its posessed, opening apps and swiping through things, zooming in and out. I have it next to me right now after restarting it and its opening apps ive never even used before.
I am really regretting switching from iphone to android, this is so annoying!
ETA: im actually on an Xperia XZ but google brought me to this thread, apologies!
