Hi
As said, My phone is opening/closing apps and swiping the screen on its own..
It can open apps, close apps, swipe/change sites all on its own.
And when it is in this state i cant even turn off the phone pressing the on/off button.
When it is in this state i cant controll the phone at all, i just have to wait until it stops wich usually takes a few minutes.
Do you think this is caused by an app or is the phone malfunctioning ?
I am using the app ''Master Cleaner'' do speed up the phone and it allso searches the apps for virus. No virus found.
Thanks in advance !
I suggest you remove the task killer,see how it goes.
Are you sure that you did not install antivirus,task killers etc,apps that could interfere with the operating system?
Ok,report here.
Ok ill try to uninstall Master Cleaner. But arent Task killers a good thing ? As there are no in-built application to kill tasks with ? And same with Anti Virus ?
You can force close your apps from settings-apps-running.It is not recommended to use such apps because they can stop apps that you need.Also,antivirus is not needed if you know you are installing from trustful sources(eg google play).
Hi i uninstalled the Master Cleaner app but the problem persists.. its writes random letters on its own.. like if its pusing the screen on its own.. if i try to close an app it will just close it again and do all kinds of random stuff =(
Do you have a screen protector?
