Hello... I'm using SONY XPERIA Z1
What can I do if I forgot my screenlock PIN?
Do I need to reset the phone?
IF reset is needed, how can I reset my Z1 at home?
@karlok wrote:Hello... I'm using SONY XPERIA Z1
Do I need to reset the phone?IF reset is needed, how can I reset my Z1 at home?
Just download sony update service and repair.
Doesn't work as it prompts you to insert sim and unlock screen before proceeding to update/repair.
SUS does not require unlock,PCC does.
I FORGOT MY SCREEN LOCK PIN SO PL LET US KNOW HOW TO UNLOCK THE SAME.
It is told in the upper posts,repair with SUS.
I forgot my screen lock password. How do i unlock it.
You have to perform a software repair using PC companion.You might need to charge your device for about 1-2 hours before so the device has at least 60% battery.
Make sure the device is not connected to computer or laptop and turned off (sometimes you have to press power button and volume up until the device vibrates 3 times or on some devices you have to press the small button near the SIM tray or on the back of the device).
Open PC companion->support zone->phone/tablet software update->repair my phone/tablet blue highlighted.Follow the steps given,do not connect your phone until prompted to press volume down while plugging USB cable.
