x
FORGOT SCREENLOCK PIN
karlok
Visitor
Hello... I'm using SONY XPERIA Z1
What can I do if I forgot my screenlock PIN?
Do I need to reset the phone?
IF reset is needed, how can I reset my Z1 at home?
45 REPLIES 45
gwhispererz
Champion
Hi, are you prompted with option to enter your Gmail account username and password after numerous attempts?
Don't forget to mark correct answer as Accepted Solution.
If you find the post helpful, press Kudos.
karlok
Visitor
No.. I'm asked to type in my PIN password again and again ><
Tags (1)
gwhispererz
Champion
You need to reset phone with PC Companion or Update Service. This process will erase everything from your phone.
http://www.sonymobile.com/gb/tools/pc-companion/
http://www.sonymobile.com/gb/tools/update-service/
karlok
Visitor
When I use the PC Companion, the phone cant connect to it. PC COmpanion has asked me to unlock the PIN but I had already forgotten it.
What should I do next?
gwhispererz
Champion
Update Service will work. Slightly_smiling_Face
karlok
Visitor
Ok.. I will try it! Slightly_smiling_Face
gwhispererz
Champion
Don't forget your pin again or don't even set one. Slightly_smiling_Face
karlok
Visitor
gwhispererz
Champion
Hi Karlok, just replied your other post. Slightly_smiling_Face
