i received an update of 341mb just 2days before, but right after update i started encountering the problem of battery like whenever the battery reaches 50% or 45% the indicator suddenly shows battery at 0% and phone shutting down. i dont knw how is it but i can certainly tell it happened after new update. please let me knw the solutuion asap
Having the same problem.
The battery drops form 84% down to 0%.
When switched on again it could be 1%, 40% or 60% (more or less)
I faced the problem when upgraded to 5.0.2
Everything was Ok with 4.4.4
Now the problem persists with 5.1.1
Rolled back to 4.4.4. - no problem.
Even if soemthing's wrong with the battery why Android 5 behaves in this way?
Hi @Curlymike @IPaltus
Seems that Google has taken on some measures on fast battery drain after Lollipop update, you can check this link:
https://code.google.com/p/android/issues/detail?id=165558
Post number 1023 is an answer from google about the reported bug.
I'm at disposal for any question.
Best Regards,
Hi @Datts @Curlymike
I suggest check these links:
http://talk.sonymobile.com/t5/FAQ/Battery-time-and-enhancement-features/m-p/347874#U347874
Best Regards,
I have to agree with all of the above, since 4.4.4 update my phone has been experiencing all of the symptoms above and more, there is something very wrong with how - either sony has adopted battery handling in LP or Google code is at fault, either way there is something not right here and I reported this months ago
as an example, I just rebooted my phone with 70% battery and it restarted with 2% and shut down
something is very wrong here
maybe they want you to buy a new phone
That means we have to wait for another update. I mean time we have to wait and wait again.
Thanks for posting the message.
