- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Xperia Z5 NFC won't turn on
Just bought this (new old stock) because it has OTG, MHL and Miracast.
Running Nougat 7.1.1 (and tells me no new version is available).
Xperia software is = 32.4.A.1.54
I followed the usual set up proceedure and all appeared to go well.
However, I then discovered the on attempting to turn NFC on, it seems to try for a few seconds, and then goes off again.
I tried it in SafeMode and got the same.
I went into = settings - support - Xperia tests and tried to run the test for the NFC. It tells me it too cannot turn the NFC on.
I then even did a full factory re-set, but even after that, it will not turn on.
I have now spent the best part of a day setting up this phone, only to find this issue.
I really need the NFC for making shop payments.
Can you tell me what might be the problem please.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Повсеместная проблема, долго ищу но пока не нашел не одного человека решившего эту проблему
A widespread problem, I have been looking for a long time but have not yet found more than one person who has solved this problem
gt
