I have huge and several problems with my phone (XZ3) after the latest Android 10 update.
-Lag, delay and slow working apps. Also between switching and opening apps.
-closing apps by itself
- clock and alarm is not working right. After sliding "turn off" it still starts ringing again.
Is there any solution to fix these problems?
I'm getting pissed, my xz3 alarm didn't call at morning and I couldn't get up for work.
Wth should we do.
Sony you better have something to say
When i clean my xperia with avg task killer (clean up ram) my xperia works fine for a while
I need to do this every week, because when i shut my xperia down the tasks wont delete thats why i think xperia is hanging all the time...
Hopefully sony is coming soon with a bug release
Try the clock app from Google. Works for me
Cheery
Mike
my problem on xz3 is restarting..again and again...it's impossible...and doesn't see sim card....i'm not using this phone almost for 2 months...do smthing plz
None of the audio settings work on my xz3 anymore. Graphic equalisers, clear audio, whatever - they have no effect whatsoever on the sound now. Considering audio was my main reason for buying Sony, I'm pretty annoyed. They need to fix this fairly sharpish.
Yea, I have noticed that also. And my phone becomes reeaalllyy slow after a few days, can take 10 seconds to opens or switch between apps. Sometimes also the sound/music starts to lag and stuttering. Then I have to reboot and it start to work again.
Hdr problem is solved with the latest xperia update. Thank you Sony.
Does new update solve alarm and camera issues
Taken a year to get my xz3 perfect and one update ruins it all.. are you gonna do to sort it?? .. My fone is possessed doin what it wants..
1) Downgrade to Android 9.
2) Enjoy your mobile.
3) Save money for a new mobile.
4) Buy new mobile.
