- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Hello everyone. There have been some white spots on the screen to my smartphone that can only be seen when the screen is white. This happened after opening it to maintain it. I would like to know what could happen and how to solve it. I appreciate any help
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
solved. The adhesive that was on the battery made pressure under the screen and that is the reason
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Basically,.
The mistake was to open it to maintain it, doing so has caused internal components to press against the display rear causing areas of increased illumination.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
And could has it any solution?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I'm not too sure,
You could try contacting your Local supportfor an out of warranty repair,
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Glad you got it sorted.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
How cost it have in repair in service centre of sony in India and could the spot increase gradually??
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi, I'm just wondering if you managed to fix this? Does it cause any issues to the phone? It's happened to mine after a screen repair?
@Alucard626 wrote:Hello everyone. There have been some white spots on the screen to my smartphone that can only be seen when the screen is white. This happened after opening it to maintain it. I would like to know what could happen and how to solve it. I appreciate any help
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
no, no, no, no! not battery adhesive, that makes no sense. how? pressure against screen most likely from tight fitting case, or excessive dropping, and /or use of a magnetic mount of some type. the neodyium magnets are suppose to be safe for the phones. maybe in a short time period they are but not constant exposure. adhesive ppffftttt!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
