As you all know, X Performance won't be available to Middle East. I'm planning to buy it online. But before that, I need to ask anyone who has the device to check if Arabic language is listed in the phone as input language. Could you check and let me know Please?
have you tried asking your local sony center support? Local support
http://www.sonymobile.com/global-ar/products/phones/xperia-x-performance/
it's not coming according to SONY. Not this year at least.
Just want to know if someone has the phone in hand to check if Arabic language is listed as an input language in the keyboard.
Thank you for your help.
i really appreciate it
Merci de m'indique comment installer un clavier arabe
Please tell me how to install an Arabic keyboard
gt
