Hi again!
I'm sorry for the late reply, I have been out of office due to vacation and I'm sorry to hear that the troubles have started again.
Is the phone updated to Nougat now or are you still running Marshmallow?
I have tried to replicate this behaviour on 3 different Xperia X Performance running Nougat, but I didn't experience the same troubles that you have.
Is there any difference if you don't "clean" the screen before turning it on again?
How often would you say this happens after turning the screen off and on again, is it a few times per day or more often than that?
You can also test the Light sensor in the phone, to do that go to Settings > About phone > Diagnostics > Light sensor, cover the top part of your screen while in test and the displayed picture should fade.
You can do the test whenever you like, I would recommend that you do it directly after you experience the troubles with the screen being dim and going darker.
Let me know how it goes and once again I'm sorry for the troubles with your phone.
Hello again!
I'm so sorry to hear about this.
I just want to confirm, after the latest repair the phone is now working correctly, and you are not experiencing the same behaviour as previously? If so, I'm happy to hear that.
I'm afraid I won't be able to assist you with market specific questions such as which service centre is being used in a specific market and the guidelines for these service centers, I work globally but I'm located in the Nordics and this vary between markets.
For market specific inquires I would recommend getting in contact with your Local support team.
I'm very sorry for all the troubles with having your phone repaired and I hope that everything will work to your satisfaction.
Please let me know if there is anything else I can assist you with!
Thanks for getting back to me!
I'm extremely happy to hear that!
Once again, I'm very sorry for all the troubles that you have been experiencing up to this point.
If there is anything else I can help you with, let me know or create a new thread on our forums and me, my colleagues and the members of these boards will do our best to help you!
