Thanks for the update!
I just tried this one a Xperia X Performance with the latest software installed and I did not experience the same behaviour when I turned off and on the display.
I'd recommend that you perform a software repair using Xperia Companion. This will delete all data stored in the internal storage of the phone so I recommend that you backup using Xperia Companion before you perform the software repair.
When you have completed the software repair, try turning the display off and on before you restore the backup.
Please keep me updated!
Hi @mbv041080, I'm sorry to hear about that.
Did this start to happen directly after the update was installed or was there a few days after you installed the update? If there was a few days after the update was installed?
I would recommend that you reboot your phone safe mode to see if a third party application is the cause of this behaviour.
Let me know how it works in safe mode!
Thanks for the update, I'm glad to hear it's working now.
It's most likely not an application that was the cause of it not working correctly since you experienced the same in safe mode prior to you performing the software repair. It sounds more like something may have gone wrong with the update and the software needed to be reinstalled.
Let me know if there is anything else I can help you with!
Hi again!
I'm so sorry to hear that.
I hope everything works out with the repair so you can enjoy a phone without troubles as soon as possible.
Let me know if there is anything else I can assist you with and have a great weekend!
