x
Can't restore home launcher
JackSpydr
Visitor
Hi all
So I started using Nova as home a few days after getting the phone. But after the nougat update it started malfunctioning so I tried to go back to the stock launcher but I couldn't find it anywhere. Does anyone know what to do or how to help anything would help
Tags (1)
1 REPLY 1
profile.country.PH.title
MarlonUk1
Expert
there should be a "home" option on the settings menu..
if not, you can try to uninstall NOVA launcher , your device should revert to the stock home launcher
