x
No more Ant+ on X models
Hekkie
Visitor
I just discovered my new X Compact isn't equipped with Ant+ where the Z models al have a Ant+ radio.
I use my Xc not only as a phone en gadget but also as a sport utility. I was deeply in love with my Z3c for this.
No problem, just buy a Ant+ dongle one would think. Actually there is a problem because the connector at the bottom of the phone is a USB-C type. Ant+ dongles are on the market with normal USB 2.0 or micro USB. For me this is a big issue.
Any suggestions, anybody?
1 REPLY 1
profile.country.PH.title
MarlonUk1
Expert
yes, unfortunately that is the case with the new series.. you can try to buy a micro usb to usb type c adapter on amazon or ebay..
