- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
September 2016
September 2016
The accelerometer of my x performance stops after some days so auto-rotate and other stuff does not work anymore until I reboot...
410 REPLIES 410
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
October 2016
October 2016
@ianchen1967 wrote:
Below solution works so far after five days's trial. No functions and apps need to be disabled.
You should remember your google account and password before going.
(1) go to Settings - Apps - App Google, press Disable, this will unstall App Google from your phone, and no need to install factory version.
(2) go to Settings - Account & sync, press Google and click right-top corner to open menu, press Remove account.
(3) Restart your phone.
(4) Enter Google play store, you will be requested to login your Google account. Do it.
(5) Search App Google in Google play and install up-to-date version of this App, then open/enable App Google. Done.
Guys,
I am going to test the telephone after the "ianchen 1967's procedure" above reported.
Will let you know if it is working on my Xperia as well.
UPDATE: THIS SOLUTION IS NOT WORKING ON MY XPERIA
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
October 2016
October 2016
Sorry por my bad English!
I found something related to the error, the proximity sensor was always on before the problem was given and now had gone with what I had to restart to function accelerometer. leave one day with error then restart today and now the proximity sensor is lit as before and has not given me the problem. (A red light that looking at where are the light and proximity sensors)
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
October 2016
October 2016
I tried to uninstall the last update of memory app and disable the AR effect app and reboot, then the rotate function seems to be stable now.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
October 2016
October 2016
Just checked my sensors with the AIDIA64 app and most of my sensors are down again.... Really annoying please release a fix for this soon Sony
step detector, orientation, tilt detector, step counter and so on are all dead...
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
October 2016
October 2016
Uninstall the What's New update really works!!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
October 2016
October 2016
Is there a known fix for this besides reboot? It's a serious problem, as it affects the camera too. My screen rotation fails after just a few minutes. Any help appreciated. Thanks
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
October 2016
October 2016
Now more than 2 days after uninstalling the memory app 1.1.A.0.1 (latest system update) without any problems in my Accelerometer and gyro.
I didn't touched the what's new, AR effects, Google services/app, nor disabling any other system app.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
October 2016
October 2016
Same problem, i brought my phone a week ago and after restarting the phone it fixed for couple of hours then it stops rotation, i made a n update software and have the latest version,,, please i need help!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
October 2016
October 2016
Sony, when will you release the update to us/ give us the solution? It would be disappointed for all of us without the target fixing schedule...
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
October 2016
October 2016
Another solution is to delete the memory update in apps and all apps scroll down to memory app open it, press the three small dots on top right corner and delete the update and restart phone. Done
