The accelerometer of my x performance stops after some days so auto-rotate and other stuff does not work anymore until I reboot...
Just over 24hr after uninstalling the system update (memory 1.1.A.0.1), it happened again.
I was just starting to think it was fine, since it was working fine 5mins ago. And now I wanted to post an update and I take the phone and it's again the same issue. No more rotation
I was kinda thinking it would since the issue for me is already occuring since before that update. I noticed it for the first time beginning of September.
OK, so unistalling the latest update, factory reset, etc don't work.
The only hope seems to be disabling (not uninstalling uptate) "what's new", which no one has been able to do after Android 6.0.1.
@joima wrote:I'm a bit confused here.
xluigi says he could "deactivate" What's New, but does it mean he just "uninstall update"?
Hi Joima,
No, there is a way to de-activate the app, in the sense that it is not active anymore (until you restart the phone, then it will be active automatically and you need to de-activate again).
The deactivation here:
settings/apps/What'sNew --> click on button upper right (Terminate or Stop ...I am translating from Italian so not sure whether you will se the same)..
@ianchen1967 wrote:
Yes, it did depend on Google service, just follow my steps (see my post on this thread) to disable Google Apps ❨this one controls Google service?) and then reinstall/enable Google Apps (newest version is okay). Everything will work fine, at least my phone is normal since 7days ago, and it works on my friends without exception. Good luck.
Hi ianchen 1967 ...do you mean one App only, right?
You mean App Google ...not all the Google Apps ...right?
