x
Accelerometer stops working
SOLVED
Mikvandorp
Visitor
The accelerometer of my x performance stops after some days so auto-rotate and other stuff does not work anymore until I reboot...
Tags (1)
410 REPLIES 410
joima
Visitor
Has anyone tried disabling what's new with this method?
http://forum.xda-developers.com/showthread.php?p=53916026
I have a feeling this may work.
Vikont
Visitor
I tried, no success .
xluigi
Visitor
Sorry guys, after a good day with Whatsnew deactivated, I opened YouTube (app) and the gyroscope failed ...and Whatsnew was deativated ...so I am lost ...seems you need to uninstall almost everything which is not an acceptable solution to me.
xluigi
Visitor
Whatsnew is not the problem ..or anyway it is not the only app giving this problem.
joima
Visitor
Vikont, thanks for response.
Does "no success" means:
you couldn't disable what's new?
or
you disabled it but sensor issue still happening?
joima
Visitor
I see. So wha'ts New probably has nothing to do with this  issue.
By the way, I just found a Japanese article saying one of Japanese carreir "au" is aware of the issue and they will provide fix "BY THE END OF YEAR".
omg..  we have to wait 2 more months?
http://sumahoinfo.com/docomo-au-softabanck-xperia-x-performance-so-04h-sov33-502so-sensor-issue-auto...
Vikont
Visitor
   or
I did these commands, but it is not apllicable for 6.0.1 I tried "hide" command, but "what's new" still working.
joima
Visitor
I'm a bit confused here.
xluigi says he could "deactivate" What's New, but does it mean he just "uninstall update"?
Vikont
Visitor
Guys! I think we need to know official position from Sony.
1. Is it possible to return this phone to seller?
2. When will this issue be  fixed?
We all their customers, we need this info ASAP.
Agree?
baha_ali
Visitor
36 hours after uninstalling the system update (memory 1.1.A.0.1) without any problems and did not reboot, Accelerometer and gyro work fine till now.
Thanks
