x
profile.country.GB.title
KmxSoft
New
Time Presentation
I have a Sony ICFCPJ.CEK clock radio. It throws the time up onto the ceiling - unfortunately its 90 degrees out of alignment, so it reads vertically instead of horizontally.
The instructions refer to 'Rotate Projection' which I assume is a button. However I don't know which button it is, and whatever I click has no visual effect.
So what exactly do I need to click?
1 ACCEPTED SOLUTION
Accepted Solutions
KmxSoft
New
Fixed it. Found button on rear of clock.
1 REPLY 1
KmxSoft
New
