Hi all
Please feel free to put in any requests for future updates and features you would like to see added. Of course we can't promise that we can deliver on all of them as there may be technical/commercial/resource limitations, as to why they aren't possible, but everything will be considered.
Thanks
Message was edited by: Thalamus.
Re-enable sticky tag
Yes the media remote app should work with your TV - maybe try doing a factory reset on the device to see if that helps...
Thanks
I believe that the restrictions on playing recorded content on another device is unlikely to ever happen - for the obvious reason of copyright and illegal distribution. I think that is fair.
However, in a bid to get more Sony TVs in to the home, it would be great if the latest crop of connected Bravia TVs could do the following:
I would have no problem in wedding myself to Sony for the these features, as it would then negate the need for Sky+ or any other PVR system.
....obvious reason of copyright and illegal distribution.
Yes, but...
Next to TV I have DVD recorder. I can record everything what I am watching.
No problems with recording or illegal distribution ?
I know, next step will be disable it. And it's called progress.
Most important:
Other wishes:
Message was edited by: Sportsock
A few wishes/recommendations for the embedded media player:
Anyway, the embedded media player is sooooooo basic!
Any 50$ media box on the market has a lot more features than this.
Sony, please add more features and codec support to the media player! Take a look at Samsung, LG and other vendors! They are a lot ahead of SONY! Why?
I did not see any official answer to any of those wishes/requests, and i don`t think i`ll see any, so this is probably my last post on this thread.
Cheers!
I don't know if Sony are actually taking note of these requests, but I will make a few anyway
I would like a way to be able to have a SEPARATE KEY TONE AND STARTUP TONE OPTION, Not Both, because at the moment I only have an option to activate key tone which also activates startup tone. I actually find the startup tone quite nice but The key tone is so annoying
I would also like to request the possibility to have a WEB BROWSER as a WIDGET. Can't see why it wouldn't be possible, already have Playjam
itvplayer seem to be doing loads right now would be great to have the itvplayer
Please Sony :smileygrin:
Thanks for all the ideas so far - do keep them coming as I know senior engineers in Tokyo have this thread URL and continue to view it and take notes.
For example this feature
Was driven by consumers requesting better social integration with their products. We should hopefully get it added via firmware later this year..
Thanks
The WHITE BALANCE controls only allow reduction of contrast (Gain), whereas brightness (Bias) can go down (resulting in black crush) or up (increased black level, lower contrast ratio), the bias settings are too strong. I did however manage to get all the deltaE under 3.
Colours aren't so accurate though because there isn't a colour management system like LG, Panasonic, Samsung and Sharp have.
Message was edited by: 22point8
Hello,
I supposed with the las update I should use hdd formatted in exFAT but it doesn't work. Does it will be possible in the near future?
KDL-46HX700
