I always use the remote and it works very well. However, I have yet to discover a way to turn it off when I have finished. When I exit it, it continues to run in the background. So far the only way I have found to stop it is to go settings and force it to stop.
Has anyone found a stop setting in the app itself?
Q
@Deadly Did you check that your recorder runs the latest update? Take a look here: https://www.sony.co.uk/electronics/support/digital-voice-recorders-pcm-series/pcm-a10/articles/00252...
I downloaded the Sound Organiser and it appears to be just that, it has nothing in it that would change the way that either the recorder operates or the remote on my mobile works.
Maybe I'm missing the point but I don't think so.
