profile.country.en_GB.title
wawamoz
Visitor
CDX-GT35U display
Hi All my CDX-GT35U display always reverts to Sony's default display after a few minutes. This consists of stuff I already know about the radio, I want it to stay on the clock or programme info. Can I fix this and how? Thanks
1 ACCEPTED SOLUTION
Accepted Solutions
Drumzman
New
Hi wawamoz,
It sounds like you have the demo mode switched on.
I think to turn this off you hold down the select button until the setup menu appears.  Then repeatedly press the select button again unitl 'Demo' appears in the display.  Turn the volume knob until the display says 'demo-off' and then hold down the select button again to exit the setup.  Hopefully that should be it.
Hope this helps.
2 REPLIES 2
Drumzman
New
Hi wawamoz,
Hope this helps.
wawamoz
Visitor
Hi Drumzman
thanks! You were right and it's fine now.
