Since having my Bluetooth Audio System moved profesionaly between vehicles after a few minutes use it switches back to display mode, any ideas how I can stop it doing this?
Hi RogerQ,
You don't say which model you have, but usually if it's the demo mode that you want to cancel, you press and hold down the 'select' button until the setup menu appears. Turn the volume dial until 'Demo' appears, and press to confirm. Rotate the volume dial again until the display says 'Demo-off' and press it again to confirm. That should be it - just use the 'Back' button to return to normal operation.
Hope this is right for the model you have - but should be something similar.
Let me know if you have any joy:smileyhappy:
Hi RogerQ,
