Hi!
I have a problem with my battery pack BP2NX with FR315M nootebook. For some time now it isn't charging even though it is inserted in it's slot and the ac adapter is conected. Everything looks the same as usuall - the indicator is flashing double times, but the icon says that the battery is charging but after a few hours it is still 0% charged.
If someone knows what to do, plaese write
Cheers!!
Make sure the contacts are clean on the battery
Use a lint-free cloth.
You battery is priobaly dead.....there is a small amount of electronics inside teh battery as well as the cells, so if there is any problem with this circuit baord...nothing works.
Most likely your only option is to buy a new battery. (if the computer is very new, you may be able to get a repacement battery unedr warranty, but I think that battery warranties are only good for about 90 days)
Yep, 90 days.
