Hi, my [FN] key is not properly working and I wonder if that could be a software problem. Is there any keyboard driver so I can reinstall the problem. Maybe another software disabled the FN-function.
Chris
Search for the file "HKServ.exe" on your C:/ drive. This will install the hotkey (FN) utilities.
HTH
HTH
Should be on your recovery disks, last CD of your set, usually in a folder called Hotkey. Else check on www.vaio-link.com if they have a more recent version available...
If it's not on your HDD then it will be on your recovery disk. Alternatively go to www.vaio-link.com and you should be able to download it there.
You're very welcome :smileygrin:
